just brought a new car and the trunk holds the bass in the truck i put 2 new cerwin vegas stroker 12s in there with a alpine hu and a rare 1100 amp punch d class mono block amp and its beatin hard as h3ll but when the trunk is close you can hardly feel the bass on the inside but on the outside the damn trunk about to fall off what can i do to make where you can feel the bass on the inside
When you say truck, do you mean a real truck? How can it have a trunk? Anyhow, if there isn't enough bass inside the car, then make some port holes into the trunk. Then the bass will "leak" into the cabin. I've seen some people make a custom hole with grills on the back seat.
i got the box facing the trunk and i turned the box every which of way and the trunk still holds the bass in. even playin at low vol. it still keeps the bass in i don't know what to do
