New Panasonic DMRE85H "self check" message????
Username: Thunder2004
Post Number: 20
Hey Guys,
Quick question I just bought the Dmre85h in Toronto and everything works fine except when i go to burn my TDK DVD-R disc from HDD-DVD-R after about 10 seconds the dubbing stops and the syste, goes into SELF CHECK mode for about 10 seconds i retry and eventually it does end up dubbing but why would i keep getting this error message?? Any thoughts?? Is it the TDK discs??
THKS
fx
"Is it the TDK discs?? "
BINGO!!
xvxvxvx
Username: Tlstrieg
Post Number: 27
I've used TDK 8X discs since I bought my E85 and have had no trouble with them at all. I've burned over 125 TDKs without mishap, but perhaps your particular machine is more sensitive to media than mine.
Tom
