JohnnyStyle Unregistered guest | How would/should I wire this: 2400 Watt Peak, mono channel amp that is 1 ohm stable, and 2 subs 700 RMS/1400 Peak each, with dual voice coils. |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1186 Registered: Sep-04 | You can't get a 1 ohm load unless the subs are dual 4 ohm. If they are it would look like this: http://www.jlaudio.com/tutorials/wiring/index.html#2dvcpp If they are dual 2 ohm subs your best bet would to wire the voice coils in series and the subs in parallel for a 2 ohm load like this, http://www.jlaudio.com/tutorials/wiring/index.html#2dvcsp but expect around half the power output depending on the amp. -Fishy |
JohnnyStyle Unregistered guest | Well Im still a newbie at this so Im a little confused. Are you talkin about this: Voice coil: 2.5" Dual 4 Ohms Or this: Operation: 2 Ohms or 8 Ohms |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1202 Registered: Sep-04 | yes and yes Wire it like the first pic with both the voice coils and subs in parallel. That'll give you a 1 ohm mono load. -Fishy |
JohnnyStyle Unregistered guest | Thank you for your help. |
Silver Member Username: GoonPost Number: 164 Registered: Feb-05 | fishy lets continue this. my subs are dual 4 ohm, i need a mono 2ohm load. the will push 500x1 at 2ohms. |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1207 Registered: Sep-04 | You can't get a 2 ohm mono load with 2 dual 4 ohm drivers howie unless use only use one voice coil. That wouldn't be a good idea for a couple of reasons one of which being that you will reduce the power handling(and output) capabilities of each sub by half. -Fishy |
Silver Member Username: GoonPost Number: 167 Registered: Feb-05 | this isn't looking good for me. |
Silver Member Username: GoonPost Number: 168 Registered: Feb-05 | does anyone know if the mtx 6500d is a 1ohm stable amp? |
