FordRanger123
Sunday, May 08, 2005 - 07:26 GMT I am getting ready to install my amp in my Ranger ext. cab. I was wondering if I could ground to the bolts on my seats that fold down or should I try to find another spot
Username: Shocksyde Post Number: 9 Registered: Apr-05
Sunday, May 08, 2005 - 12:56 GMT you should attach the ground wire to a bolt directly on the chassis sand down the area around the bolt to bare metal as well, this will help prevent signal noise
FordRanger123
Sunday, May 08, 2005 - 20:51 GMT So I have to find a bolt under my carpet to ground right?
Username: Tragedy San Jose,
CA
Post Number: 225 Registered: Feb-05
Sunday, May 08, 2005 - 21:03 GMT u can use a seat bolt to ground to.. just install your ground wire underneath your carpet and not on top.
