Perfect 12's
Username: Fillymo
Post Number: 15
Has anyone heard these in action I blew my Jbl Bp1200.1 . Thinking about selling my solo baric for 2 Infinity perfect 12's then buying another jbl bp1200.1 Any ideas.
Username: Its_bacon12
Post Number: 223
a 1200.1 will put WAYYY to much power on infinity kappa perfects, the most any infinity sub can handle i believe is 400w rms and a 1200.1 would put out 600w to each one which i would not reccomend doing
jfgfffffffff
What if He puts 3 : )
Post Number: 226
3 would work but they would have to be the single 4 ohm versions or dual 2 ohm version
wire the dual 2 ohm version in series tog et 4 ohm per sub, run the 3 subs in paralell to get a 1.3 ohm load on the amp and sicne it puts the same at 1 and 2 ohm, youll still be getting 1200w rms, 400w rms to each of the 3 subs
