Ok...Im putting all my questions into this thread....Plz help.
Username: Dano9258
Post Number: 19
Ok. Here it goes. I am re-doing my system in my car. Here are the specs:
2 12" Audiobahn 550rms 4ohm svc
1 Power Acoustik 1100 rms Class D Mono Amp
Ok....i plan on just unhooking my old system and installing the new one. My fuses on my current amp are 30x2 (so 60a). I dont know what the inline is at b/c i dont know where that fuse is.
My alternator is a 105a.
My questions:
1) Can i get this all to work with my original alternator?
2) Does anyone know what to replace the inline fuse with? Or even where the inline fuse it?
Thanks.
1)
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1133
1) determine what gauge power wire you have
2) find the inline fuse
3) if you can't find it you need to put one in
4) get back to us after you've done 1) and we
can help you.
5) almost forgot. this is probably the most important. RTFM. no manual? do 1) and get back to us
-Fishy
WC
I would buy a cap.
Username: Dano9258
Post Number: 20
A cap? Is that a battery?
Also:
1) If i buy a second battery just for the system, is that possible?
2) What is RTFM?
Thanks for all of the help so far. Its been wonderful.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 385
man, theres a lot of counting going on in this thread, lol
RTFM means read the f-ing manual
Username: Solacedagony
New Jersey US
Post Number: 387
Batteries and capacitors won't do jack for you if your alternator can't keep up with everything else. Adding that stuff will just add MORE strain onto your alternator.
A capacitor simply stores electricity for those times when you get huge bass hits and you need that power faster than it can be supplied simply from your alternator.
