Polk or infinity?
Username: Safa19
Post Number: 10
are the polk audio db6500 any better than the infinity reference 6010cs? their the same price at crutchfield.com but i was wondering if there is any big difference or if it is just personal opinion? also wat would be a good amp for them? thanks.
Username: Shouder
Wisconsin
Post Number: 131
I would recomend the infinitys all the way. Even infinity's lower models are better made than others mid or higher end. Ive had good experence with my infinity subs, and have never heard any other supported negative responses towards infinity products.
Username: Skyliner17
Saint Paul, MN United States
Post Number: 26
i would go infinity also. i have the infinity perfects and i have heard the polks, infinity sounds clearer and i like their bright tweeters.
Username: Safa19
Post Number: 12
thanks that helps alot because i am ordering them offline and havnt heard them so all i could go by was what they gave for statistics thanks again.
Username: Safa19
Post Number: 13
what would be a good amp to power the infinities and 2 infinity 6x9 3 way speakers? for a reasonable price
