2 channel amp to 1 sub, series or parallel
Username: Vctrmaso
Clifton, New Jersey USA
I have a rockford p8002. Its a 2 channel amp that i want to run bridged with my one 12" L7 kicker. I was wondering weather i should run it parallel or series, and whats the difference between the two configs. The specs on the amp are here http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?Item Key=10063523&CategoryDesc=Punch%20Amplifiers
Username: Sevin7
Post Number: 84
if your L7 is dual 2 ohms then you want to wire it with one positive to the other negative, and one negative to the other positive... cant member if thats called series or parrallel, but that will give you a 4 ohm load, and that amp puts out 800 @ 4ohms.
Username: Vctrmaso
Im prety sure its dual 4 ohms because the manual says it could be rigged up at 2 ohms or 8 ohmes. Should i still wire it up the same way even if i get 8 ohmes?
