well, are this go well with nad c320bee&c352? or have you another suggestion for that budget. I mostley listen rock, chill out, some jazz, reggea. is it true that I can't get much bass from ae? and is it difficult to run? thanks
the AE will suit that combination fine. It doesn't have big bass but it has good bass. It rocks well and is an involving listen. Place it on a decent stand and it will work fine.
Oher competitors for similar money would be the B&W DM303, also very good - and the B&W DM600 which is great fun.
