what are the best subs im going to be able to get off of ebay for around 130$/ i've notived RF's P2/ Infinity 1230/kickers(almost any model) and some other ones but whats going to be the best( im looking for 2 12" subs)
if your talkin pairs get the kicker c 12s youll only need 300 rms power and youll have decent output esp. in a ported box preferably on the larger side if your going to buy a box already built
what do the older ones look like(can you send me a link) because i don't want to go with the wrong stuff... also what type of amp do you recommend/ and do you think i should go sealed or ported box with these???
El Cheapo
are there any other subs that will be better or just the same as the kicker(like RF or Audiobahn?)
and why are the older ones better then the new? is there any specific reason
