LAVA 2600
Username: Sapin23
I have a LAVA 2600 Sat Receiver and I'm receiving scramble signal. How can I fix this issue. What type of software do I need? I see a lot of PanSat and BB on this messageboard and I was wondering if LAVA is a good brand? Would I need to input keys like the PanSat? I'm able to capture radio stations and some channels but of course scramble would appear on the upper right hand corner of the screen when I switch from Radio to TV after proccessing Ch Scan. Any information on this matter would be great.... Thanks!
Gregg
I have a LAVA 2600 up and running continuously for almost 6 months. Its good and cheap. Just have it flashed by your dealer and point it to Dish.
http://www.ioffer.com/i/LAVA-2600-LAVA2600-FTA-RECEIVER..-BLOW-OUT-WEEK-5562172
Username: Maple_leaf
Post Number: 191
Never heard of it so i can't help.
Username: Sapin23
Is their a site were I can get it flash because this receiver was giving 2 me...(No dealer) I have it pointed to Dish Net so I guess it seems the receiver needs to be flashed. If you know of a site that will be great.
Post Number: 193
I looked around can't find anything about it. Try doing a yahoo search on it .
