Wiring question
Username: Thenoose
Post Number: 60
ok i have 2 single 4 ohm voice coil subs and my amp is mono i know about series and parallel but can someone plz give me a step by step to do this and tell me how many ohms i will be running so i know thanks
PHIL@OKC
WHAT IS THE LOWEST RESISTANCE FOR YOUR AMP?
Username: Thenoose
Post Number: 61
2 ohms
Username: Thenoose
Post Number: 62
plz anyone
phil@okc
I would just wire them in series, theoretically they should work in parrallel but when I did my 6x9 in parallel thr amp used its self protect deal, even though it said I could do two ohms. If you are not two picky about it just do series. other than that dont blow your amp when expiermenting
Username: Nnnnick_b
Nc Usa
Post Number: 329
wire in parallel. this will result in a 2 ohm load.
Username: Bdb_86
Bemidji, MN Usa
Post Number: 231
i would wire them parallel
Username: Subfanatic
Walton, Ky
Post Number: 3113
guys, he wanted to know how, this is how, ill show you
http://www.jlaudio.com/tutorials/wiring/index.html#2dvcpp
4th picture down
Username: Thenoose
Post Number: 63
sub i love u thanks hahaha
