RMS and peak
WC
Ok, I was going to get this amp kit that is for 800 watts, but my amp does 500RMS and 1100W peak, should I get the amp kit thats for 1500 watts?
Username: Carguy
Post Number: 2636
When you're shopping for amp kits, go by rms numbers. Try and get one that's higher than the amp.
WC
I was going to get the RF CP4POS, its for 800 watts, I dont know if its RMS or peak, does anybody know?
Username: Carguy
Post Number: 2655
When in doubt, then treat it as rms and get 4gauge kit.
WC
Aight then, I'm getting the CP4POS, because the other RF amp kit for 1500watts is almost $100.
