4000 PRO null cable
Username: Donj
Hello,
I am new at this and tried to download software to my brand new unit. I was not able to get it to comunicate with computer. I suspect this is a problem with RS cable that I have. What cable should I use. Does anyone know the arragenment of pins
Thanks
Don
Username: Maple_leaf
Post Number: 156
Need to know what unit it is. There's 100 of them out there.
anyone know if digiwave 7000 is any good?
Username: Donj
Hello,
I am new at this and tried to download software to my brand new unit, Coolsat4000pro. I was not able to get it to comunicate with computer. I suspect this is a problem with RS cable that I have. What cable should I use. Does anyone know the arragenment of pins
Thanks
Don
Post Number: 166
Go here they have a whole section on them. Register then you have access to them ok. Remove the # sign.
http://www.al7bar.t#k/
