Vented or sealed ?
pound tha ground
which is better a vented box or a sealed box
Username: James1115
Wilton, Ct
Post Number: 2670
it all depends on what you are trying to achieve, All out SPL or SQL or straight up SQ, Also what types of music you listen to.
word
depends on what you are looking for, sq- sealed, spl- vented. although, if a ported box is built to the correct specs it can have just as good, if not better sq as sealed and it will be louder. Ported also requires less watts to get the subs moving.
