Hey I was wondering if anyone had expericne with Precison power amp or if it would be around the same as a JL 1000/1 as of powering 2 W6v2 in a JL enclosure. I was thinking of bidding on this on ebay so if anyone could answer that would be good. thanks
PPI's newer amps are nothing compared to the older ones. if you have the dough deff. go with the JL 1000/1. ive heard good things about Orion amps try finding one of those with the right power.
