How loud are the Atlas 12"s
Username: Drpthemc
Atlanta, GA USA
Post Number: 8
im gettin 2 atlas 12's on monday... i was just wondering how loud they are... will they rattle my whole car and blurr my vision? :D :D :D... oh btw what is a decent cheap amp that will power them very nicely?... as some already know i have a g@Y a$$ boss amp... and i want to upgrade... but dont feel like spending alot of cash...
Username: James1115
Wilton, Ct
Post Number: 2660
kicker kx 400.1 I believe is the model #. that will work well with those subs, and wont break the bank. look on Ebay.
Username: Drpthemc
Atlanta, GA USA
Post Number: 9
hey james do u know anyone that has those subs?... if u do... are they really loud? ill check out that amp.. thanks :D
Username: James1115
Wilton, Ct
Post Number: 2663
I dont have the atlas I have the Avalanche. JW on here has an Atlas and he loves it. I have heard great great things about them especially how efficient they are:-)
Username: Drpthemc
Atlanta, GA USA
Post Number: 10
haha ic... thats cool man... do u have the avalanche 15?... i heard that 2 atlas 12s are as loud as the 15's... not sure if its true. but thats what i heard... btw does ur avalanche hit like crazy?
Username: James1115
Wilton, Ct
Post Number: 2667
yeah it gets pretty loud when I want it too:-) almost too loud sometimes and I am running it sealed, I cant imagine what it would sound like in a low tuned ported enclosure, it would be sickening at notes around 25htz:-):-):-)
Username: Drpthemc
Atlanta, GA USA
Post Number: 11
muhahah... im so excited cant wait until they come... sucks being a n00b at car audio... i wish i knew a lot lol... hmm how do u tune ur box?... i always see stuff about that. i have a ported box, and im wondering how i would tune it or whatver... btw will my box be ok for the (2) atlas 12s?... i think it will be o.O
Username: James1115
Wilton, Ct
Post Number: 2669
I think chad recomends sealed for the Atlas doesnt he? I cant check on that right now for you but I will check it out and get back to you. You tune a box by changing the port size and depth, the smaller and shallower the port the higher the tune, the bigger and deeper the port the lower it is tuned.
Username: Drpthemc
Atlanta, GA USA
Post Number: 12
hmm i forgot wat chad recomended... err i dont want to buy a new box!!! lol holy moly car audio is freaking expensive... if i keep the ported will it be better for SPL?...
