Kenwood in 86" cutlass supreme
Username: Baumer8907
im 16 and just bought a 86 cutlass supreme which i love and i just got a kenwood head unit and i was wondering if i had to buy a wiring harness or not and if u dont no how do i find out if i do. Also i was wondering if anyone new the stock speaker sizes so i can replace them with new ones
Username: Illuminator
Post Number: 115
I'm not sure about the speaker sizes, but for the wiring, you're going to need to buy a harness that goes between the factory plug and the harness to your Kenwood. One side of it clicks into the factory plug and the other side consists of wires that you have to crimp to the harness coming from the headunit via butt-connectors. Here is a picture to help illustrate(the aftermarket harness in the pic):
I got this pic from http://www.bcae1.com/
ok thanks for the diagram hoffaly i should be able to figure it out
