An important Question to ask??????
Can you run 2ch. off your Headunit even though it is a 4ch. say for example a 50x4(22x4rms)??????????
Username: Carguy
Post Number: 2521
Are you trying to use only 2 channels? The answer is yes.
However, unlike amps, you can't bridge them to get more power.
yes i was thinking of just using my HU to power my rear speakers so i can use a good 2ch. amp to run my components in the front... so how much watts(rms) would i get out of 2ch. from a headunit for the example i said before?
Username: Carguy
Post Number: 2524
No more than 20w rms max. Good enough as rear fill.
thx!!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7746
yes you can use only 2 of the 4 channels.
no you cannot bridge 4 channels into 2 to get more power from a head unit.
so say if the rear speakers rms are 80-90 depending on size of speaker will running them off a HU be efficient enough?
