Silver Member Username: LangnerMadison, South dakota US Post Number: 113 Registered: Apr-05 | if you have 2 4 ohm subs and a 2 channel amp and you wired + on subs to the + on the amp and - to - with both subs to seperate channel for each sub how many ohms would that be??? |
Silver Member Username: ByrumjrPost Number: 204 Registered: Jan-05 | 4 ohms if the sub is single voice coil |
Silver Member Username: LangnerMadison, South dakota US Post Number: 116 Registered: Apr-05 | yea it is |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2771 Registered: Dec-04 | only 4 ohms, svc is svc no way around that unless u wire it with another sub |
New member Username: Robste15Post Number: 5 Registered: Apr-05 | say you are wiring 2 subs that are 4ohm dvc then wiring them in parallel will make them a 1ohm according to...http://www.diamondaudio.com/products/pdfs/Single%20Dual%20Wiring%20BW.pdf |
