Turning Stereo into surround sound
David P. Brennan
I bought a 5.1 SS kit for my PC a while ago but dumbass forgot that i needed to have a SS sound card! I heard off a friend that you can split the stereo signal and make it come out of all the speakers. I know it wouldnt "Technically" be surround sound but i would at least be surrounded by the sound! I cant afford a sound card so does anyone know if there any cheap DIY method of doing this?
Username: Joe_c
Oakwood, Ga
Post Number: 242
you can get a stereo mini splitter at radio shack for less than ten bucks and plug the fronts and backs into it
David P. Brennan
Hmm well i guess i'll have to look for the irish equlivant to Radio shack!! Thanks though man... ill give it a shot
Username: Joe_c
Oakwood, Ga
Post Number: 246
tandy
