Crossover placement?
Username: Dantzler803
Fredericksburg, VA USA
I also have the same perfect's but 5 1/4's. I have a soundstream 720 4-channel and infinity 6x9's. Where do you install the x-overs in a Cadillac deville?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 509
As close to the speaker as possible.
What do you think about the soundstream amp on the infinity's? And exactly what location close to the speakers? Thanks for the info.
Where do most people put them?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 513
I have a Soundstream amp on my Infinity's and I wish I would have waited and bought a better amp. Any place that crossover fits is where you want to mount it, but it should be as close to the speakers as possible. I have mine mounted in the bottom of the door panel, and I just drilled a hole so I could run speaker wire through to the speaker and crossover.
