I have 2 12" jl W6v2's and they are dual 4 ohm... ok and i have a MTX 1501d amp that is 2 ohm stable. Will my amp work ok if i wire my subs 1 ohm????????? And i assume my amp will put out suffiecient power right???
Do not wire the subs below the resistance that your amp can handle or you will be sorry. If you need a cheap 1 ohm stabloe amp with that kind of power, look at the Hifonics BX1500D.
