Bronze Member Username: Basketballinu05
Post Number: 27 Registered: Dec-04
Posted on what would be a good amp for the 15 inch atlas sub |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 381 Registered: Mar-05
Posted on Any decent amp that produces 250-300 watts would work nicely. SOmething like an Xtant 301A would work well, or an RF 301M. |
Post Number: 28 Registered: Dec-04
Posted on is the xtant 301 a mono amp or what and who makes the rf 301m
Post Number: 29 Registered: Dec-04
Posted on but wait isnt the atlas 4 ohm so wouldnt i need an amp bigger than the 301A since it would be running at 4 ohms |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2372 Registered: Dec-04
Posted on PPI a300.2 |
Post Number: 30 Registered: Dec-04
Posted on who makes the PPI a300.2 |
Post Number: 31 Registered: Dec-04
Posted on who makes the PPI a300.2 and thats a 2 channel amp right so would you guys suggest a 2 channel amp or a mono d amp |
Phoenix,
AZ
Post Number: 392 Registered: Mar-05
Posted on PPI makes the PPI, and Rockford Fosgate makes the RF301M. The PPI would be better than the other two I suggested. |
