Stuff to stop boot viabration noises
Username: Sexxybeast_5
Geelong, Victoria Australia
Post Number: 33
hey what is the best solution to stop the boot from raling it anoying as f''k
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 288
dynamat or something simular and expanding foam
Username: Araknid
BOCA , FL U.S.
Post Number: 419
Its almost impossible to completely stop it from rattling so get used to it.
Username: Carguy
Post Number: 2332
Not unless you weld/bolt them down.
