How about this? am i choosing the right stuff?
Username: Terps297
Potomac, MD USA
Post Number: 92
is this setup quality or am i cheaping myself and should i get better stuff
Alpine 9853
Diamond HEX S600s 6.5 components
Ascendant 15" avalanche
Soundstream VGA800.2(for av) and 600.2(for hex)
knukoncepts wiring
Optima red top battery
150 amp alt
Username: Araknid
BOCA , FL U.S.
Post Number: 414
Good stuff. You need a enclosure tho.
Username: Jwbulger79
Florida
Post Number: 453
looks good.
Username: Terps297
Potomac, MD USA
Post Number: 93
i've been trying to contact chad at ascendant to inqure him about having them build a box and send it with the Av. would this be the best route or should i just build my own box.
Username: Abew330
Camarillo, Ca Usa
Post Number: 41
i'll get better amps..
Username: Invain
Michigan United States
Post Number: 1933
Depends on how much it costs. If you had them build just a sealed box with an Avalanche in it, I'm sure it wouldn't cost very much. I do know sometime in the future Chad want's to start building Snail Shells for the Atlas's and Avalanche's. When you find out whether they can build one for ya, tell me, because I'd rather them build one than myself.
Florida
Post Number: 457
if you want a ported box, and you've never built one, you may want to let him build it. if you want a sealed box, build it yourself. they're pretty easy.
