Bronze Member Username: AudiomaniaMuskegon, MI USA Post Number: 17 Registered: Dec-04 | I want the Hsu VTF, but it comes only with spikes. I have newly refinished hardwood floors. What's are my possible solutions? I don't want to diminish the effectiveness of the sub in any way. Thanks |
Silver Member Username: Touche6784Post Number: 248 Registered: Nov-04 | stick quarters under the spikes or some other material. you could try small pieces of carpet or maybe cloth. |
Bronze Member Username: Reggie_livesPost Number: 28 Registered: Dec-04 | My understanding is that, from an acoustic point of view, a carpet would be best, considering it's downward firing. |
Unregistered guest | Just set the spikes on these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=38076%26item%3D7314098761 %26%26 or any variety of hard rubber furniture leg protectors you can probably buy at Wallyworld. |
