Widescreen gaming problem on Sony 960 XBR
Username: Zachwhite0
When I play a xbox game that has 16:9 support I am only picking up 4:3
I have the xbox set to widescreen
I have monster component cable
I have a 34" sony 960XBR which tells you the resolution and format when you hit display. When I am playing a 16:9 game it says 480p 4:3
When it is on Normal mode I get 4:3 and when It is on Full mode I get a stretched 4:3 image. The rest of the modes are zoom modes.
Like I said before Normal has it in 4:3 and I get black lines on the sides. When its on full. Everyone looks like they are 350lbs. In the manual it says FULL mode is only for anamorphice previously stretched stuff. So once I do pick up a 16:9 signal which mode should I use?
Anyone got any ideas as to what else I could try?
