How do you set up more then one amp per sub?
Ok say you have a 3000W SVC 2 Ohm sub. And you have 4 identical 760W mono amps. How can you wire the 4 amps to the sub? Do you need additional hardware?
Thanks!
I this possible?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 247
they would have to be strappable. you can hook 2 to the sub, 1 per coil, any more will have to be strappable. strapping amps also increases their current draw too btw
