David B. help pls
Username: Msully701
Stratford, Connecticut US
Post Number: 32
I notice that your the most knowledgable on component speakers. im getting 2 kicker 12" L7's and a kicker kx 1200.1 you said stock speakers WONT sound good. you advised Infinity 6000CS. if I were to put these in do I just take the stock speakers out and put them in or do I have to get an amp and such like I do for my subs?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 144
Thanks for the compliment.. but I am not the most knowledgeable on speakers or anything for that matter. L7's are very loud subs, and you were to put them in that small a vehicle without revamping your front speakers you are only going to hear your subs basically. Components don't need an amp, but they would like more power than a head unit can give them. What kind of head unit do you have? A small 75X2 @4 ohms amp would do the trick nicely though. If you have a budget problem you may want to hold off until you can gather more money, you get what you pay for. On a side note, why are you wanting to get 2 L7's?
Username: Msully701
Post Number: 33
I like loud music, and bass. Might enter a few dB comps
