Enough power?????
Username: Tlo211
Post Number: 22
Im thinking about buying a Kicker KX400.1 (400watts RMS x 1 @ 2ohms, Class D, 25 Hz subsonic filter) I'm going to try and power my Kicker solobaric 12" L7 (750watt RMS) DVC 4ohm (wired for 2ohm) sub with this amp. The sub is in a vented box. Will this be enough power? I want my sub to be loud, but I don't want my sub to wear out any time soon. Also I don't have a lot of money to spend on an amp, and I can pick up this amp for only $160. Thanks for the help.
Username: Glasswolf
sure it'll work, you'll just have an underpowered sub.
baller, where can you get it for $160? i am looking for that particular amp. The cheapest I have found it for was $250. please reply.
Username: Hydro
Post Number: 129
Norm theres a place called HMD Distributors on Ebay its a Store who just so happens to carry Kicker Amps.Im not too sure if they have any of that Model as of now but you can check and eventually you will find one at there Store.I have done buisness with them Before very Honest Store
Username: Tlo211
Post Number: 24
Norm... http://thewholesalematrix.zoovy.com/product/KICKERKX4001
