Entry level subs
vsvas
What are good entry level subs for car audio novices?
Any input apreciated.
Username: James1115
Wilton, Ct
Post Number: 2128
whats your price range? I dont really believe in entry level subs cause there are always a good sub for someone's budget.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 471
yeh like RE re line of subs. Those are supposedly entry line subs, but there still louder and sound better than some manufactuars middle line to top line equipment
vsvas
My price range is $120 to $150.
vsvas
My price range is $100 to $150.
vsvas
sorry for double post
Username: James1115
Wilton, Ct
Post Number: 2131
in that range look into www.reaudio.com , www.ascendant audio.com or www.imagedynamicsusa.com check out the RE line from RE, the Atlas from Ascendant audio, and the ID and IDQ series from image dynamics. All great stuff. Also look into Cerwin vega v-max if you want to.
vsvas
How about Alpine-R? Are they good?
I saw in lot of threads here.
Username: James1115
Wilton, Ct
Post Number: 2132
yeah they are OK I really am not that impressed with them personally but there are alot of people on here that like them. I havnt heard the new ones but I really am not a big fan of the old ones.
vsvas
Thanks for the inputs.
Username: Jwbulger79
Florida
Post Number: 428
for the price, you cant beat the atlas.
Username: James1115
Wilton, Ct
Post Number: 2133
thats the route I would go also:-)
Username: Creative
CA USA
Post Number: 12
How about Infinity Kappa Perfect 12.1? Are those any good for beginners if I want SQ and some SPL?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 117
Yes, they are good; but it also depeds on your enclosure. For the price of the Infinity Perfect, I would rather have the Ascendant Audio Atlas 12".
Username: Creative
CA USA
Post Number: 13
Which enclosure is good for the infinity perfect?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 153
SQ- sealed box to specs of sub. SPL-ported box to spec of sub.
