New member Username: CabutlerPost Number: 1 Registered: Jan-05 | I have just bought a KISS-DP558 DVD HDD recorder, I was wondering if anyone has a region hack for this player! I cant find one any where! Thanks |
New member Username: QuelchPost Number: 1 Registered: Feb-05 | Hi. I can't connect my Kiss DP558 to my PC. I'm using a router and I've entered the IP address like the manual says but whatever else I try it can't find the connection. The manual's not very clear - does anyone have an idiot guide for someone with no knowledge of networks etc. - or can point me in the right direction? Many thanks. Thanks. |
DutchD Unregistered guest | Check this website: http://www.mpeg-playcenter.com Here you can find everything about the DP-558 and other Kiss players. DutchD |
Mdoolitt Unregistered guest | Hello Joe & Chris Where did you get your DP-558? I'm having trouble finding it in the US. |
