2 Amps to 1 Sub
Is this a good idea? thanks
Username: Jmloughrey
Farmington, CT
Post Number: 1093
depends if your sub can handle it....you can run an amp to each voice coil...thats basically what you've gotta do with an RE MT...
Yes I meant to say that. Basically I already have one 400w amp (at 2 ohms) and I can get another one for very cheap. So I could get a DVC 2 ohm sub and run one to each coil. Just wondering if this can be done and if it's a good idea. I guess the settings on each amp would have to be the same for it to work right? well duh
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 838
I wouldn't.
Just get two subs... unless your limited on space. Two subs with 400 watts will usually be just as loud(or louder) than one of the same off 800. In general you get a get a 3 dB increase when you double the power or if you double the displacement. Two subs would actually be louder in this situation if the one driver reaches full excursion at less than 800 watts(very common for most subs).
-Fishy
it's just I could get an SX or somethign for under 300. I can't think of another sub that is 150 a piece that would give me about the same SQ/SPL (with two)
Alpine Type R 2005
Username: Fishy
Post Number: 841
Don't forget the price of another amp(including install).
If your dead set on one SX sell the amp you have and get a bigger one.
-Fishy
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 84
Possibly a couple os Atlas 12"? They are $150 a piece and only need like 250 watts.
