Bronze Member Username: Trev87Glennville, Georgia Usa Post Number: 47 Registered: Dec-04 | plz someone answer me and be for real when i say this casue im a noob and i was stupid and bought a legacy amp and i cant take it back so if u had this amp what sub or subs would u get for it it says its a 2 channel 1200 watt amp so in ur answer plz be serious ok thank you trevor |
Bronze Member Username: Trev87Glennville, Georgia Usa Post Number: 48 Registered: Dec-04 | well here is a link to the amp its the same one mine is just 1200 watt instead of 1000 http://www.ikesound.com/product-product_id/571 ive kinda liked the alpine type r sub so with this amp do u think i could power 1 or 2 12" alpine type r's? and how do yall think it would sound and hit with just the one alpine type r ? thanks or if u had this amp or have had this amp what would you get i wont something atleast as powerful as a type r if possible thanks |
Silver Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 829 Registered: Sep-04 | How many watts RMS is that amp rated for? My guess is that its a whole lot less. How big of fuse does it have? A "true" 1200 watt amp would require at least a 100 amper. My 1000 watt Xtant has two 60's. You probably won't want anything more "powerful" than those type R's. -Fishy |
Bronze Member Username: Trev87Glennville, Georgia Usa Post Number: 49 Registered: Dec-04 | ok well thats what im gone get then is the type r but idk anything about my amp so should i get 1 or 2 12" type r and should i get an 04 type r or an 05 type r? and if i just get one how do u think it would sound and hit in your opinion ? |
