Can you split the tv out cable
Username: Djgo_42
Post Number: 21
Can you split the TV out cable from a pansat so that the same channel can be seen on 2 different TVs in 2 different rooms. What type of splitter do I need? Thanks DJ
Username: Maple_leaf
Post Number: 94
Yes you can split it but it may not work good because of voltage drop.You can get a splitter any where for coax or rca's plugs. Rat shack or like store.
Username: Djgo_42
Post Number: 22
Thanks Maple Leaf
brandon xxx
can I connect my pc to an audio amplifier so I can hear a song I downloaded from the net?
Post Number: 115
If you have downloaded a song to your pc, you don't need an amplifier, just play it through it your pc speakers
