I have a Clifford Solaris w/remote start and window control. Before this morning I have never had a problem.. Normally when I push the button to start, it work fine.. Flashers blink twice and it starts. But this morning, I pushed it and the flashers blinked four times and nothing happened. I tried again, got the same result. It worked fine last night, then this morning I get this. I tried lookin online for the flashing codes to try to troubleshoot, but I found nothing. Any help appreciated, Thanks.
Jon B
That usually is a problem with your hood, or trunk pins... Check them and see if they are properly aligned
