New member Username: Vic631Ny Us Post Number: 3 Registered: Mar-05 | HO`W CAN YOU enter new keys into these receivers? only flashing with a PC? or can it be done using the remote control like the fortec... |
Ray5213 Unregistered guest | COOLSAT PRO you can access the KEYS MENU by pressing "8282" on the remote and you have access to change the keys manually if needed. Once in the menu the INFO button will cycle thru A-F for your letters. |
Anonymous | what is dreambox? |
Satz32 Unregistered guest | Ray5213 you seem to know about Coolsat Pro. I did a bit of reading on Coolsat and ordered one last week to be delivered on Wed 23 March. If I need help with setup can I contact you? |
LK Unregistered guest | Coolsat and Dreambox,both have stayed working through ALL the past 4 key changes ...no new keys were needed to be manually changed.. |
Lk Unregistered guest | Sat..al7bar.t*k (remove the *) has all the coolsat files and HowTo's and setup guides.. BTW...this site no longer allow to type alrbar.t*K or dsscentral.ne*t WITHOUT the *...this site ECOUSICS doesn't want people using the GREAT services of those sites |
New member Username: RashtPost Number: 2 Registered: Mar-05 | how do i switch between dishnet and bell express |
steelerfan Unregistered guest | i have tried everyway i know and everyplace i can to press in 8282 and nagravision is supposed to come up? is this supposed to be done with it hooked up to the TV? that is where i have been trying it. or hooked up to the pc. im ready to toss this thing into the depths of the ocean and let the sharks watch satallite |
steelerfan Unregistered guest | by the way its a coolsat 4000 pro |
New member Username: StreetpunkPost Number: 1 Registered: Mar-05 | Do any of you guys know were i can get the coolsat 4000 pro (not plus) package, the one that has the todoial dish? |
Anonymous | Ecoustics is a HUGE waste of TIME!!! |
hecktor hymenall Unregistered guest | i would look in the forums here c00lsat just look in the free to air section of forums |
San Diego Unregistered guest | that is a useless link to a web hosting site.. heres a much better site, BTW...all here know I speak the truth! |
Portland Unregistered guest | latest keys and autoroll bins are here..along with How to guides and readme files..new keys are posted immediately,and the "getkeys" software is there too.. https://www.ecoustics.com/electronics/forum/home-video/129425.html |
