5.2 SURROUND SOUND~WANT GLASSWOLF INPUT
gonna buy a cheap 80 dollar 5.1 surround sound, split the signal going to the sub, run it and split it too the two Earthquake tnt 300 amps, ran to two ten inch kenwoods in a vented box. also have one thunder 5000 12. is this the best decision for amps? it would be nice to go with one amp. my current limit is 36amps so no amp with a fuse rating over that. 4 ohm subs. already have psu's ran in parallel for 12V@36A for in home car audio:-) let the ideas roll in.lookin for somthing from glasswolf
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7521
I dislike using car gear in home.
I'd suggest using a home sub, or a 120VAC plate amplifier for the car sub(s) and enclosure
