Boston Unregistered guest | Current keys from stream log..3-24 as of 10:30 PM EST Key 0=D5 6F BB 83 00 D8 B0 4E Key 1=11 B1 AA A7 8B 9E 45 8B If U use the autoroll bins for Pansat and Fortec,then U wouldn't need to change the keys...thats what the autoroll does for you! These are keys for dishnet and will work on any receiver,irregardless of make/model...How to input is the ONLY difference between various make/models...Bev/Bell has NOT changed keys since Nov 2003,so the channels and satellites there are not affected.. If U want the latest keys,files,autorolls bins/flashes,How To guides etc, for any receiver go to the link below..U will have to register (username and password of your choice)...this is a FREE public,non selling/spamming respectable safe friendly site..this site is always open and doesn't go down when there is heavy traffic and busy nights with key changes like tonight.. [link removed] |
Anonymous | Thanks Boston, any autoroll for BB yet? |
Boston Unregistered guest | not sure..I know there are new BB files tonite at the link above.. |
Boston Unregistered guest | Everything U need is right here in this topic and link.. BTW..BB files posted tonite have the new keys in the bin..and the latest Fortec and Pansat 2300 and 2500 autoroll bins and uploader.. |
New member Username: MorganlucasTX Post Number: 1 Registered: Mar-05 | I don`t know what I did with my key for the Bell Bev, but I could not see them any more.... I know that if you have to change the key for the Dish, you do the following: MENU PARENTAL CONTROL SECOND PIN 0000 NAGRAVISION OK PROVIDER ID 0001 KEY NUMBER 00 OR 01 KEY DATA (THE CURRENT ACTIVE KEY) OK FOR 2 SEC. EXIT TO CHANNELS But how do I set the Bev keys on my PANSAT 2500 Someone.. Help please |
Boston Unregistered guest | Bev/Bell has NOT changed keys since Nov 2003,so the channels and satellites there are not affected.. But here are the Bev and Dish keys,and thats NOT how to change the keys..with Dish keys U select dishnetwork...with Bev,U select bev/bell.. Current BEV Keys AUX0 is active, changed Tue Nov 18 20:00:00 2003 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA Current Dish Keys KEY0 is active, changed Thu Mar 24 18:00:00 2005 KEY0: D5 6F BB 83 00 D8 B0 4E KEY1: 11 B1 AA A7 8B 9E 45 8B THIS is how to CORRECTLY change keys.. https://www.ecoustics.com/electronics/forum/home-video/128842.html |
New member Username: MorganlucasTX Post Number: 2 Registered: Mar-05 | Boston, Thank you for the info. But I still can`t see BEV on my Pansat. I think a reset my equipment when a put the keys of the BEV, this is what I did by error: PROVIDER ID 0000 (I THINK PUTING ALL ZEROS RESET MY SATELLITE OPTIONS) KEY NUMBER 01 AND 00 KEY DATA (CURRENT BEV KEYS) OK EXIT If I want to change de PROVIDER ID, there is no longer options, just DISHNET. If I press the right side volume of my remote control to change provider nothing happens... If you could help me, I appreciate.. |
Anonymous | I have same problem. What is the Provider ID for Bell ExpressVu? Can someone go into Parent control and checkout Provider ID for Bell (like Dish has 00 01)Thanks. |
Boston Unregistered guest | go to [link removed] ...register first there and ask...U will get your answers. |
Silver Member Username: Jmill1948Chester, Va Usa Post Number: 607 Registered: Apr-04 | KEY1 C1 E0 C4 E8 FF 86 50 41 Active |
Silver Member Username: Knee_grows_backPost Number: 131 Registered: Jan-05 | the only thing active is your wife...ROTF |
Anonymous | this new keys are not working for me i keep geting only some channels can any body help im very new at this |
Silver Member Username: Knee_grows_backPost Number: 132 Registered: Jan-05 | sorry no-one can help you...you are useless...you should switch over to cable that way you can watch TV without whining...this FTA is way too complicated for your simple mind.. |
Anonymous | ty u for your help kneegrow now you could go back to what you were doing (sucking on your d) |
New member Username: MorganlucasTX Post Number: 3 Registered: Mar-05 | Hi, I found the PROVIDER ID for the Bell Express Vu, the number is 0801. Thants the number in other to put the key for the BEV. You do the following in your Pansat 2500: MENU PARENTAL CONTRO SECOND PIN: 0000 NAGRAVISION PROVIDER ID: (DIAL YOU RIGHT VOL. KEY UNTIL THE NUMBER SHOW: FF FF, THE CHANGE TO THE FOLLOWING NUMBER 0801) KEY NUMBER: 00 KEY DATA: 82 D7 51 E4 5B 97 9D 81 OK FOR 2 SECONDS EXIT TO CHANNELS Thats how you do it.... now you can enjoy Dishnet and BEV. |
