Bronze Member Username: Doug_wPost Number: 31 Registered: Mar-05 | Is there going to be any difference in sq or spl if I use a 5/8" MDF box vs. a 3/4" MDF box? Or is a 5/8" MDF box just as good as a 3/4" MDF box? |
Silver Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 890 Registered: Sep-04 | If its a small enclosure for a moderately powered subwoofer then no, you probably won't notice a difference, especially if you use bracing. Here's a couple good links: http://www.jlaudio.com/tutorials/boxdesign/index.html http://www.jlaudio.com/tutorials/bracing/index.html As you can see the JL guys are bracing fools, in fact I think they use 1" MDF in some of their W7 enclosures. -Fishy |
