New member Username: Caddy94Post Number: 2 Registered: Mar-05 | what amp should i buy to run 2 solo baric l7 15's there 1,000 watts each | |
Silver Member Username: Addicted2bassMiami, FLORIDA USA Post Number: 441 Registered: Nov-04 | How much are you looking to soend. And also what kind of enlcousure are you going to use. | |
New member Username: Caddy94Post Number: 5 Registered: Mar-05 | i want to spend about $400.00 and there going in the the square solo baric box
Gold Member Username: JmloughreyFarmington, CT Post Number: 1082 Registered: Jul-04 | i beleive those subs are 1000peak, run about 500-600 watts of good clean power into each sub and you'll be banging like crazy... | |
New member Username: Caddy94Post Number: 6 Registered: Mar-05 | i found a amp kicker kx1200.1 would that push both of the subs how much watts will i be pushing in both subs 1200 watts at 1 ohm | |
Silver Member Username: Addicted2bassMiami, FLORIDA USA Post Number: 447 Registered: Nov-04 | i would recommend an mtx audio 1500d amp. THere anps are good also. |
