Apline CDA - 9835 - HELP
Username: Rapids101
I bought this new head unit the other day after deciding to upgrade from my previous unit the CDA-7875. All was well and dandy when installing. After which I turned it on for the first time and it seemed to work. But after a minute only half the screen seemed to be lighten up... Has anyone else encountered this problem before... I tried pressing the reset... nothing... I think I might have a dead unit... What do you think?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 263
sounds like a dead unit .. take it to the shop u bought it from and get them to test it to see if its a dead unit
