New member Username: The_fishermanPost Number: 3 Registered: Feb-05 | Autoroll binary file works. There are two bin files in this download, be sure you use the one for your pansat unit. I just turned on my tv and it went to downloading data. At 400% the program came on and I checked the keys. New ones were in place. New keys for today:Key0 B3 E1 DF 37 5E 75 8A B5 Download Autoroll here: The fisherman@iname.com |
Boston Unregistered guest | Remove the * from the .ne*t link above..copy/paste it into your browser...the link is the latest files and keys.. |
Anonymous | This new little program that get the keys instantly. you can download it and keep it on your desktop. this and much more can be found in the fta files section of hashu. FTA INFO |
