Bronze Member Username: MrvfPost Number: 11 Registered: Nov-04 | Hi, This sensor on avantguard is dual zone (warning and full trigger)right? In my avantguard just work full trigger zone...where is the problem? On sensor...programmation? Thanks |
New member Username: ParadroidPost Number: 5 Registered: Jul-05 | Page 61 seems to show how to test/adjust the trigger zones. http://clubgtinorfolk.com/downloads/alarm-manuals/clifford/avantguard5_install.p df |
Bronze Member Username: MrvfPost Number: 12 Registered: Nov-04 | Yes Gavin, i just read this and at test modes it works fine. But when activate the alarm and bump the car the alarm just full trigger. It is bad adjusta?maybee... |
Bronze Member Username: MrvfPost Number: 13 Registered: Nov-04 | When i bump the car in test mode, full triger and warn way zone the siren chirps 1 time...it means i hit hard enough to activate sensor, correct? If this test is ok means the sensor is ok too? When i go out test/adjust mode and activate alarm to test the omnisensor it just works full trigger. Any ideas Gavin? Thanks for this installation manual, it have good information. p.s - sorry for my english, im portuguese |
New member Username: ParadroidPost Number: 9 Registered: Jul-05 | The warning zone works when someone is 'near' your car, not when you touch the car. It is designed to warn someone if they get too close. By hitting the car you are triggering the 'full' alarm. |
