Anyone with Infinity Kappa 10" I need HELP!!!
Username: Blazemore
Building a Truck theater system around a Soundstream 5.1 amp for the kids on long trips. The sub channel is rated at 1x200 @ 4ohm, 1x400 @ 2ohm, or 1x500 @ 1ohm. The sub I have is a Infinity Kappa 10 DVC (4ohm). I'm building a seal box around .8ft^3. Can the sub take 400 rms or will I run into problems with durability over time. See I f@ckup and got the kappa instead of the Perfect. I will be pushing the sub 125rms over the rated by Infinity (which is 275), will this work?
Username: Subfanatic
Walton, Ky
Post Number: 1384
you can run it at 2 ohms and thenjsut turn your gaines down ALOT and just hope you can set it low enough to where you wont damage anything
Username: Shab
Tampa, FL
you need more power for a sealed box.... your fine about over powering them they are made to take a beating!!! GL
BanGinG said it. if its in a sealed box and you're giving clean power, it should be alright. infinity's got durable stuff. but still keep a close eye on it if you really crank it up loud.
