I'm very new to this, so I purchased a Panasonic A/V Receiver SA-HE70 100W x 5, paired w/ Jensen speakers for my daughters room. I only have a Philips 32" stereo TV hooked to it, yet after 10-15 minutes of my daughter using the system at a moderate level, the receiver cuts itself off and OVERLOAD flashes across the digital screen. Is it possible I have it hooked the wrong way or could it be something major. The system is very inexpensive, but it was just to entertain my daughter's friends in a 12 x 13 room.
Ag96
I have the SA HE200 with Bose Jewell cubes. I received the same message until I followed the manual and switched the setting to Low Impedance. You may have low impedance speakers 4-6ohms. Follow the manual on how to switch to the low impedance setting. The trouble shooting section of the manual will have other suggestions.
Ag96
You may also want to use the A speaker terminals only. The A&B settings are 6-8ohms. The A or B setting is 4-8ohms.
