New member Username: In4niPost Number: 1 Registered: Feb-05 | Getting ready to make my first FTA purchase. What is the ultimate hardware setup to be able to receive maxinum channels. how bout a dish500 and a 30" with with a motor? Will that combo work? thank you |
New member Username: WyrtwisterPost Number: 5 Registered: Feb-05 | Two ways to go . Put a DVB-S PCI sat card in your computer or buy a FTA receiver ( Pansat 2500A or a Fortec Ultra ) . If you are using a motor , there is no need for a twin LNB . If you want true FTA , you need at least the 30" dish & a linear Ku LNB . If you want to " test " DN & BEV , put an old 18" DTV dish & LNB on the motor . If you want both , strap a DTV LNB to the side of the 30" dish & linear KU LNB . Use a Diesque swirch . Wyr |
LK Unregistered guest | I'm hearing very good things about the coolsat over the pansat...Much faster and EPG working very soon..many I know have both...all prefer the coolsat |
working EPG Unregistered guest | Coolsat 4000 has a working EPG |
New member Username: In4niPost Number: 2 Registered: Feb-05 | Sure is amazing how off subject these threads get |
LK Unregistered guest | Actually this thread is Exactly on subject,unlike most other threads.. |
New member Username: WyrtwisterPost Number: 6 Registered: Feb-05 | Is the EPG on the CoolSAt on DN or BEV ? What is the coast of this IRD ? Does it use Pansat or Fortec flashes ? Thanks , Wyr |
LK Unregistered guest | has its own software...prices vary based upon dealer..220-280...EPG software release this week.. |
Anonymous | Wyr wait for the new model release Coolsat PRO march 1'st it's much better and a supposed epg release on Saturday. weel see... |
Bronze Member Username: AllicPost Number: 13 Registered: Jan-05 | A fortec with multi dish is the best! We have the best deals on the |
JayBeeZee Unregistered guest | can anyone tell me if the coolsat 4000 pro can receive bev.... ty |
LK Unregistered guest | Bev/bell has NOT changed Keys since November 2003....and I have posted those keys here at numerous places..also KEY changes APPLY to ANY FTA receiver...all the same,make-model makes no difference Current BEV/ Bell Keys AUX0 is active, changed Tue Nov 18 20:00:00 2003 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA The Dishnetwork Keys work on ALL makes/models of FTA receivers...Pansat..Fortec etc.. Current Dish Keys KEY1 is active, changed Thu Mar 17 17:00:00 2005 KEY0: F0 C9 59 D8 7F 8D 34 13 KEY1: 0B 51 9E B7 EB 20 E7 4D BTW...here's where/how to get and use BOTH the Pansat 2500 and 2700 autoroll bin v245,which does work..its in this linked thread below..READ! https://www.ecoustics.com/electronics/forum/home-video/127878.html If missing channels after a Key change install,..always shut power OFF on BACK of receiver,unplug,wait 1 minute,plug ,turn back ON..if that doesn't fix it,then do a AUTOSCAN (or can add new channel list using Gtools 1.86) via the remote in your installation setup again. |
JayBeeZee Unregistered guest | i have a coolsat 4000 pro and when i look in my list of satellites it only has two both dish net sats but not bev how do i get more sat choices on that list ty again |
