11.5mm or 24mm? please help
Robert J
if you have 12inch sub and the xmax is 11.5mm and a 10 inch sub that has a xmax of 24mm, will the 10inch have lower bass then the 12inch because it is moving more air, or will it just be louder?
Username: Its_bacon12
Post Number: 268
it could probably hit lower frequencies and it will be louder than that 12 inch
