New member Username: J_2_tha_cSydney, Nsw Aussssstralia Post Number: 2 Registered: Mar-05 | i am hooking up two audiobahn subs with 600 watts each goin into them and then i just have normal kenwood 4 inch speakers running at the 52 watt ouput of the head unit what should i do to get the best quality sound, good for all types of music from punk to dance etc. p.s my amp doesnt have a crossvoer it has little dials for treble, bass and gain so im not sure if i use them or not??? thankss heaps |
Gold Member Username: SubfanaticWalton, Ky Post Number: 1123 Registered: Dec-04 | whats a crossover |
Silver Member Username: Jwbulger79Florida Post Number: 290 Registered: Nov-04 | get some bassblockers for your 4" speakers. http://www.crutchfield.com/cgi-bin/ProdView.asp?i=127BB600a2 |
Silver Member Username: Jwbulger79Florida Post Number: 291 Registered: Nov-04 | they are essentially capacitors, or simple passive crossovers. http://www.the12volt.com/caraudio/cross.asp http://www.bcae1.com/xoorder.htm |
Silver Member Username: Jwbulger79Florida Post Number: 292 Registered: Nov-04 | if you want to save a couple bucks, you can get two of these: http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=027-356 hook them up to the positive side of your speaker wire. they are the same thing as the 600 Hz Bassblockers. |
